Forums >> Revit Building >> Technical Support >> Axis in elevation is funky
Wed, Mar 25, 2009 at 10:01:11 AM | Axis in elevation is funky
velvetseas
I am trying to draw things in elevation views, which up till now has been workign just fine, but all of a sudden my lines and masses are being drawn along some weird axis in the foreground.  Is there a way to "reset" the axis or something?  My building is rectangular, so I don't know where this odd axis came from.
Wed, Mar 25, 2009 at 10:09:12 AM | Axis in elevation is funky
It sounds like you are using model lines.  Be careful!
Model lines, found under the basics or modeling tab, are 3 dimensional and they have to be placed on a plane.   This plane is defaulted to the floor level on plan views but it can be setseperately.  In all other views, you must set the plane.
Detail lines, found under the drafting tab, are 2 dimensional and will only show in the view they were created in.
Wed, Mar 25, 2009 at 10:18:48 AM | Axis in elevation is funky
velvetseas
In this instance I was actually tryign to draw a mass on the face of a building.  I had drawn several earlier today, but I don't know what I did that is making the ones I'm doing now draw on the funky axis.
Wed, Mar 25, 2009 at 10:53:15 AM | Axis in elevation is funky
Just like 3d lines, masses are 3d elements and they are created from a plane of reference.  You need to set the plane you are working from when you create a mass element.
Wed, Mar 25, 2009 at 11:04:52 AM | Axis in elevation is funky
velvetseas
Okay.
I'm just so confused why things won't draw on the rectangular face of my building.  I didn't do anything to change the reference plane of my drawing.
Wed, Mar 25, 2009 at 11:06:38 AM | Axis in elevation is funky
velvetseas
I should ask then how to create a reference plane....
i'm only haveing the axis issue in my South elevation.  Every other view is working fine.
Edited on: Wed, Mar 25, 2009 at 11:07:24 AM
Wed, Mar 25, 2009 at 12:58:52 PM | Axis in elevation is funky
Levels and grids are reference planes.  You could use one of those if close enough.  If not, go to a plan and from your basics tab, click on reference plane.  Draw one along the face of your building ... let it extend out beyond it.  Click on the plane then right click and get to the element properties of the plane.  Give it a name like .... south side.... Now you can go to your south elevation and you can set your working plane to south side...
Good luck
Wed, Mar 25, 2009 at 1:07:48 PM | Axis in elevation is funky
velvetseas
I tried drawing a mass and selected Set Work Plane, then chose the face of my building.  I noticed that the default work plane for the south elevations was changed to be hosted by the one cylindrical object in my building.  Not sure how to change it back, but thanks for the help.
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Topo elevation reports different value than actual location on z-axis in model
Wed, Sep 26, 2018 at 11:47:41 AM
rotating in Y axis?
Wed, Feb 13, 2013 at 3:30:01 PM
Revolve along a curved axis?
Tue, Apr 1, 2008 at 3:40:01 PM
Changing Level 1 to match site information
Wed, May 7, 2008 at 4:25:00 PM
Page generation time: 0.6120
