Forums >> Revit Structure >> Technical Support >> How to combine (merge/join/link?) Revit Structure and Architecture files?
Tue, Mar 24, 2009 at 10:28:12 PM | How to combine (merge/join/link?) Revit Structure and Architecture files?
piece0cake
I'm doing a project using Revit.  I drew the walls and windows in Revit Architecture, and the structural system using Revit Structure.  I realized I have an issue when I need to cut a section, but my building is in two pieces.  Is there a way to combine the files other than copy-pasting one into the other?
Wed, Mar 25, 2009 at 2:06:03 AM | How to combine (merge/join/link?) Revit Structure and Architecture files?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, just link the two files into each other...  File-->Import-->Revit
Regards,
Chris.
Walls- merge regions
Sun, Feb 29, 2004 at 4:04:10 PM
merge or combine mesh
Mon, Jul 24, 2017 at 6:44:54 AM
Area Plan - merge or combine areas?
Mon, Sep 9, 2013 at 4:32:00 PM
how to merge a MEP Engineering project into Revit Architecture Project?
Thu, May 3, 2012 at 11:55:07 PM
Metalic Structure in Revit Architecture
Fri, Dec 3, 2010 at 1:10:10 PM
Page generation time: 5.7730
