Forums >> Revit Building >> Technical Support >> changing line thickness in composite walls
Tue, Mar 24, 2009 at 6:55:14 PM | changing line thickness in composite walls
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
Revit 2009
Lets say I use composite wall which is made of  timber stud, cavity and brick externally (brick veneer). Is it possible to change line thickness of of either stud wall or brick wall only , basically to assign different line thickness to wall components?
Wed, Mar 25, 2009 at 4:22:21 AM | changing line thickness in composite walls
tim123
4 Stars: 19 Votes
You can use the 'Overide graphics in view' function to change the display of individual elements.
Wed, Mar 25, 2009 at 7:11:09 AM | changing line thickness in composite walls
What tim123 says will work only for the category cut lines, not the individual wall component lines.
To do what you want, use your linework tool.
Changing wall thickness issue
Thu, Oct 12, 2006 at 11:07:14 AM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:35 PM
View Title Line Thickness
Thu, Jan 24, 2008 at 1:42:39 PM
composite panel walls
Fri, Feb 25, 2011 at 1:32:37 PM
Line thickness in detail family
Wed, Jul 1, 2015 at 7:09:56 AM
Page generation time: 2.5725
