Forums >> General Discussion >> Revit Project Management >> Using specific info from Linked Model Worksets
Tue, Mar 24, 2009 at 6:22:54 PM | Using specific info from Linked Model Worksets
cadmonkeygonewild
Working on a project with Revit MEP-Structure & Architecture.
On the plumbing plans I want to bring in just the mechanical equipment that will require action from me...like condensate draining, or a boiler that requires water. The Electrical team needs all the Mechanical equipment that requires power like AHU's and from me booster pumps, etc. Is there a way to bring just those items over as a link (in case something moves or is added) and leave all the other stuff like duct, etc behind? I know that we can bring in the model and uncheck things in visibility graphics but the whole model is still there and taking up memory (RAM). If there is a way to do this, is there also an easy way to "toggle" back and forth between just those equipment items and having the whole model?
Only thing I can think of is some modifed View Templates.
Thanks
Wed, Mar 25, 2009 at 6:53:32 AM | Using specific info from Linked Model Worksets
Check into the copy/monitor process.
Autodesk A360 - Linked model don't appear
Wed, Jan 4, 2017 at 4:49:01 AM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:37 AM
turn on/off worksets in a linked model
Fri, Sep 8, 2017 at 3:39:16 PM
linked file elements on host workset...help
Fri, May 4, 2012 at 5:46:58 AM
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:31 PM
Page generation time: 1.3447
