Forums >> Revit Building >> Tips & Tricks >> dimensions???
Tue, Mar 24, 2009 at 3:57:53 PM | dimensions???
jnordby
I need to be able to do dimensions in architectural and in metric at the same time??? I know autocad does this easy. How does revit handle it???
Tue, Mar 24, 2009 at 6:20:04 PM | dimensions???
jarosa
jarosa Avatar
4 Stars: 5 Votes
Not so easy....
Here's a tip from AUGI
Need to show a drawing with both metric and imperial dims?Set a dimensions style to your metric version then copy it and rework it with imperial settings but set the dimension position to be below the line and to the right - defaults are left and above.Place your metric dimension then place an imperial dim in the same location so that the dim lines are coincident and you will appear to have one dimension with both measures.
Or you could just place on dimension below the other. Either way double your time dimensioning.
....good luck.
john
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 0.7832
