Forums >> Community >> Newbies >> Flush bifold door - no panels!
Tue, Mar 24, 2009 at 1:16:10 PM | Flush bifold door - no panels!
jmhartline
Okay, full disclosure: I've only been using Revit for a few days...
Does anyone have a flush bifold door? I've got to complete a progress set for this coming Monday and I can't seem to figure out the family editor for doors.
Tue, Mar 24, 2009 at 1:43:40 PM | Flush bifold door - no panels!
4 Stars: 205 Votes
Did you search here in Downloads Section???? search for "flush bifold door"...
Tue, Mar 24, 2009 at 1:47:41 PM | Flush bifold door - no panels!
jmhartline
Yeah. Inexplicably there isn't one there.....
Tue, Mar 24, 2009 at 2:12:25 PM | Flush bifold door - no panels!
4 Stars: 205 Votes
Try here: http://revit.autodesk.com/library/html/index.html
or here: http://www.revitcomponents.blogspot.com/
or here: http://www.cadforum.cz/catalog_en/
or here: http://seek.autodesk.com/
or here: http://www.revit.com.hk/index.php?Itemid=7
Tue, Mar 24, 2009 at 2:42:43 PM | Flush bifold door - no panels!
jmhartline
Tried them all with no luck. Thanks for the links, though....
Anyone else have any ideas?
Tue, Mar 24, 2009 at 2:52:12 PM | Flush bifold door - no panels!
4 Stars: 205 Votes
Well, in this case I think this is the day where you gonna start to learn how to create your won doors....
Edited on: Tue, Mar 24, 2009 at 4:11:46 PM
Tue, Mar 24, 2009 at 3:13:35 PM | Flush bifold door - no panels!
jmhartline
Yeah, it looks like it. If anybody has any tips, let me know. I'll post my finished model in the downloads section....if I can figure it out...
Tue, Mar 24, 2009 at 6:46:22 PM | Flush bifold door - no panels!
jarosa
jarosa Avatar
4 Stars: 5 Votes
Open the panel bifold family. Select and edit the door panel extrusions. Delete the portion of the door panel extrusion that forms the "holes" for the panels. Select and edit the panel extrusion.  Delete the "panel" extrusions. Delete the dimensions for stile and rail widths (if any are remaining). Remove the parameters in the family for stile and rail widths. You will have to tab to select the two different extrusions for each panel. You'll need to do this for two families if you want bifolds with 2 leafs and 4 leafs. If i'm thinking this through correctly you should end up with a flush bifold in about 10 minutes for each family.
Typhoon, did i miss anything?
I have a door project in the download section. Check it out. I'll be adding sliding closet doors and now flush bifolds soon.
Wed, Mar 25, 2009 at 6:39:36 AM | Flush bifold door - no panels!
jarosa
jarosa Avatar
4 Stars: 5 Votes
I uploaded this door to the RevitCity Download section. It's not in my Door Project upload yet. You still should do the 2 section door on your own for practice.
John
Edited on: Wed, Mar 25, 2009 at 7:56:37 AM
Wed, Mar 25, 2009 at 8:36:20 AM | Flush bifold door - no panels!
jmhartline
Thanks!!! I'll definitely go through the exercise, but that saved me some time. It seems to be in short supply these days.
6 panel bifold door
Tue, Jan 26, 2010 at 2:03:12 AM
Curved bifold (multi-fold) doors
Mon, Oct 30, 2006 at 10:40:41 PM
curtain walls make like partition walls
Sun, Oct 26, 2008 at 2:03:28 AM
BiFold Swing Door family - whacked out
Wed, Dec 2, 2009 at 3:07:37 PM
Revit only showing me one door type; flush door
Sat, Nov 17, 2012 at 6:31:39 PM
Page generation time: 0.3414
