17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Low walls still room bounding??
95 Posts No Rating |
Hello, I just noticed a oddity with my rooms, and I can't figure this out. I created a bunch of rooms, after which the client decided to lower some of the walls to be 4' high. At this point, these walls don't seem to be room bounding any more, even though the Element Properties say otherwise. Is there a setting at what height rooms are being cut? Please advise. Thanks for reading! I've attached a screenshot of how defining a new room is ignoring a 4' heigh wall.
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer |
It doesn't matter how tall the wall is so this should not happen Are you sure all of these walls are set to be bounding? Are you sure all of these walls rest on the floor? Are you sure the walls in question fully define the space? Is the room on the same level as the walls?
Are you sure all of these walls are set to be bounding? yes Are you sure all of these walls rest on the floor? yes Are you sure the walls in question fully define the space? yes Is the room on the same level as the walls? yes In fact, I just created a new full height room, with a smaller low height wall inside of it. By default, those walls are room bounding. See screenshot.
using RAC-2013
If the walls are lower than the computation height then they will not be room bounding. This level can be adjusted in the level properties.
That was it!! Thank you so much!!! I then had to adjust the View Range to be below the computation height for the rooms to show up.
using RAC-2013
Interesting tim ... I have never messed with this - always left it set to automatic and not had any problems. Learn something new everyday ...
The lowest wall I have will be 4' height, so I set the computation height at 3' and the view range bottom to be at 2' I would not have thought to check this out. Thanks again guys.
using RAC-2013
room bounding problem |
Fri, Jul 28, 2017 at 4:03:50 AM
13
Room Bounding - Room area changes, then changes back for no reason! |
Wed, Apr 28, 2010 at 6:22:40 PM
Room Bounding Families |
Wed, Mar 31, 2010 at 5:35:10 PM
Trouble getting furr down walls @ ceiling to actually be room bounding.......... |
Tue, Jan 26, 2010 at 11:58:10 AM
BIG curtain wall room bounding problem!! |
Mon, Dec 14, 2009 at 9:31:31 AM
