Forums >> Revit Building >> Technical Support >> Keeping Columns in Place
Wed, Jun 29, 2005 at 5:46:29 AM | Keeping Columns in Place
remashiach
My columns keep on moving with elements such as walls. I want them to be locked to the grid lines ONLY or to stay where I put them. I have tried pinning them and they still move. I have tried aligning them to the grids and the "locking" it but when I then try to move a wall it doesn't let me as it says "Constraints are not satisfied". What am I missing? Please help!
Wed, Jun 29, 2005 at 7:43:22 AM | RE: Keeping Columns in Place
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Try selecting the columns and unticking "moves with nearby elements" and see if this helps. I am aware of a bug with columns moving, but (touch wood) i'm yet to experience the problem first hand. HTH.
Wed, Jun 29, 2005 at 7:48:40 AM | RE: Keeping Columns in Place
remashiach
Thanks but I do not have that option in the "properties" box of the column. I only have "move with grid" option to tick or untick.
Thu, Jun 30, 2005 at 7:56:45 AM | RE: Keeping Columns in Place
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This option doesn't appear in the properties box. It show at a check mark in the top status bar directly above your main model window... HTH.
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Wall based embeded angle not keeping hd stud in place.
Tue, Apr 5, 2016 at 2:49:55 PM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
Columns using Revit 213
Mon, Mar 11, 2013 at 5:49:52 PM
Page generation time: 0.5182
