Forums >> Revit Building >> Tips & Tricks >> need help to load a rte file....
Mon, Mar 23, 2009 at 6:24:50 PM | need help to load a rte file....
ireyes
3 Stars: 1 Votes
how do i load a rte file on a existing project?
i tried loading the file as follows:
-file
   -load from library
       -load file as group
but i have no option to select a rte file.
i have attached a link that has the rte file that i want to load.
http://seek.autodesk.com/product/latest/agg/usg/United-States-Gypsum-Co-USG/19
I. Reyes
4th Yr. Architecture Student
Illinois Institute of Technology
Revit Architecture 2009
Tue, Mar 24, 2009 at 7:58:36 AM | need help to load a rte file....
A rte file is not a project file, it is a template.  You can use that when you start a project and/or you can open it directly.  Once opened, you can transfer project standards from a new file created from this template to an existing file but that will not get you everything.  Some items will have to be copy/clipped and pasted into your file.
Cannot get the Mechanical-Default_Metric.rte template to load
Sat, Jun 9, 2012 at 2:30:21 AM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
RTE vs RVT
Thu, Sep 26, 2019 at 9:21:04 PM
Use .rte object in my .rvt
Fri, Dec 4, 2015 at 12:44:24 PM
Due to a technical problem - my ISRENU.rte file gone missing!
Wed, Aug 3, 2011 at 6:03:04 AM
Page generation time: 2.5404
