17 Users Online (15 Members):
Forums >> Revit Structure >> Technical Support >> Wall Mounted Light Problems. . .
1 Posts No Rating |
so i have this wall mounted light that works great, with the exception that it mounts to 3 in from the wall's centerline and not to the face of the wall. i have removed just about every constraint and lock that there is in the light's family, but i think the problem is because of these reference planes that will not delete. also, when i move these certain reference planes, many of the lights elements move with it. . . any suggestions???
Sorry but it looks like you will have to re-build this family correctly. Because Revit creates associations between elements, I like to build wall faced elements off a work plane that is named and located more than 12" off the face of the wall. Then I will add a dimension from the face of wall to this reference plane ... set it to 0 and lock it which then moves everything to the face of wall.
wall mounted toilet wall error |
Wed, May 6, 2009 at 3:41:37 PM
Ceiling mounted light family |
Tue, Feb 1, 2005 at 9:04:23 PM
Handrail - Wall mounted |
Fri, Apr 28, 2017 at 5:35:54 PM
Wall mounted carriage / lantern lighting |
Thu, Feb 11, 2016 at 8:25:27 AM
handrail, wall mounted |
Fri, Feb 13, 2009 at 1:47:36 PM
