Forums >> Revit Building >> Technical Support >> Stair Railing Profiles
Mon, Mar 23, 2009 at 11:38:06 AM | Stair Railing Profiles
naterfisher
4.5 Stars: 3 Votes
I'm trying to create Corbusier's Villa Savoye stairs in Revit and I cannot get my railing profiles to cooperate because the handrail requires 2 closed loop profiles in 1 file; the pipe rail at the top and then the rectangular wall rail beneath it.  Please see the attached image to understand what I'm trying to do.  Perhaps there is a way to have 2 seperate handrail profiles for 1 stair set, or maybe their is a wall to have a wall host to a stair and then I can attach the pipe handrail, I do not know I hope someone can help me.
 Thanks in advance
Mon, Mar 23, 2009 at 11:43:56 AM | Stair Railing Profiles
JRMello
You should be able to edit the railing's type properties, and under Rail Structure clikc the Edit... button. You can then Insert a second rail with a different profile and give it a different height, offset etc. HTH
Mon, Mar 23, 2009 at 12:03:20 PM | Stair Railing Profiles
naterfisher
4.5 Stars: 3 Votes
Brilliant, thank you
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Stair Nosing Profile Help
Thu, Feb 21, 2008 at 8:29:59 AM
Page generation time: 0.3489
