Forums >> Revit Building >> Technical Support >> Elevator / Maint. Pit - Revit Architecture 9
Mon, Mar 23, 2009 at 10:32:39 AM | Elevator / Maint. Pit - Revit Architecture 9
joeinck
Howdy,
when i create a building section, the 'Earth' poche cuts out correctly around my building put does not cut out around elevator and maintainence pits, it just goes right through these areas? I have foundation walls and floor slabs defining these areas?
thanks
j
Mon, Mar 23, 2009 at 10:47:28 AM | Elevator / Maint. Pit - Revit Architecture 9
Add another pad to cut your pit.  Under the site tab.
Mon, Mar 23, 2009 at 11:46:49 AM | Elevator / Maint. Pit - Revit Architecture 9
joeinck
yes, i tried that and have attached a dwf of the results. it does not work correctly as you will see. this seems like such a simple issue, drafting 101. i have even tried making these areas into rooms but still no luck. i have made the bottom of the pit an actual level as well, but no luck. what if this was a partial basement...would i have the same problem?
thanks for your input, it got me a little closer, at least i dont have earth in my pits
j
Mon, Mar 23, 2009 at 12:25:52 PM | Elevator / Maint. Pit - Revit Architecture 9
Sorry but pads do work correctly when done right.
First, the pad should be defined to the outside of your pit walls - not the inside.  This should take care of the line at the top of the topo.  Remember - this is just like you build it.
Second- the line at the top of the wall / bottom of the slab would be there in real life - unless you plan on puring the wall with the slab.  But - if you want to get rid of the line, use your join geometry tool - that is assuming the pit opening in the floor actually matches your wall location.
Third, I assume you will be placing another pad for your other pit?
Finally - you don't need a level or rooms to make this work ... but if you want them....
Mon, Mar 23, 2009 at 2:57:08 PM | Elevator / Maint. Pit - Revit Architecture 9
joeinck
The plot thickens....
it would appear that if i have multiple contour lines in my Architectural site plan, i need to merge those surfaces, which is not so good if you want to show the site grading. i did the other things you suggested and they worked great as long as i only have one topo surface?
j
Mon, Mar 23, 2009 at 3:33:54 PM | Elevator / Maint. Pit - Revit Architecture 9
I'm not sure I understand.  Why would you have more than one topo surface .... or do you mean you have a split surface?
Did you look at graded regions on your site tab?
Mon, Mar 30, 2009 at 2:20:14 PM | Elevator / Maint. Pit - Revit Architecture 9
joeinck
I was confused, just getting used to the site contour stuff. I appreciate the solution and will keep working on developing my site plan and watch how it effects my building sections
j
working with Pads and toposurfaces
Fri, Jun 8, 2007 at 3:17:49 PM
need help on elevator...
Fri, May 25, 2018 at 4:23:17 AM
CALCULATING THE RIFLE PIT ?
Mon, Jul 28, 2008 at 4:00:31 PM
Slab edge with different profiles
Tue, Oct 11, 2016 at 11:23:26 AM
New Elevator Family
Wed, Sep 13, 2017 at 6:42:18 AM
Page generation time: 6.9267
