Forums >> Community >> Newbies >> Column Confusion
Sat, Mar 21, 2009 at 3:29:05 PM | Column Confusion
Darrell
I'm attempting to create a column family. I created the column, loaded it into the project, yet I can't seem to adjust it's height. Changing the top level setting does nothing. What have I done wrong here?
Sat, Mar 21, 2009 at 3:35:09 PM | Column Confusion
jarosa
jarosa Avatar
4 Stars: 5 Votes
did you lock the top and bottom to the levels in the family before loading it?
Sat, Mar 21, 2009 at 3:45:49 PM | Column Confusion
4 Stars: 205 Votes
Good Question...
Sat, Mar 21, 2009 at 3:51:29 PM | Column Confusion
Darrell
Thanks for the quick responses. I did not lock it to the levels. How do I go about doing that?
Sat, Mar 21, 2009 at 4:10:00 PM | Column Confusion
jarosa
jarosa Avatar
4 Stars: 5 Votes
This is basic to Revit but here goes. In elevation, start the align tool. click the upper level. Click the top of the column. Make sure you select just the top. then lock the lock symbol. I'm not positive you need to lock the bottom but go ahead and do so.  Load into project. Now your column will adjust to height just like a wall you can constrain or offset to any level.
Sat, Mar 21, 2009 at 4:41:06 PM | Column Confusion
Darrell
got it. Thanks for the help.
Confusion on Rooms
Fri, May 23, 2008 at 10:53:27 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
tags, symbols and annotation confusion
Thu, Jan 17, 2008 at 11:13:31 AM
L shaped column
Mon, Jun 22, 2015 at 4:37:29 AM
Page generation time: 2.6141
