Forums >> Revit Building >> Technical Support >> label with formula
Fri, Mar 20, 2009 at 2:13:08 PM | label with formula
kristyvz
I'm trying to make a room tag with a formula to calculate the number of occupants by dividing the area with the occupant load factor.  I have attached the label.  I have loaded it into my project and added the shared parameters, but the formula doesn't work.  It comes in as a number to input.
Can you tell me how to get the formula to work or where to find a tutorial on it?
FYI- I'm pretty new to revit, just stumbling my way along.
Fri, Mar 20, 2009 at 3:55:59 PM | label with formula
Dasher
You can't. It's been asked fopr since Version 2 I believe. You have to manually put in the number to calculate (code occupant load)
adding a formula to a label
Wed, Jul 29, 2015 at 8:59:07 AM
label parameter formula
Thu, Apr 26, 2012 at 12:15:03 PM
Improper use of Boolean Expression message with my calculated value formula
Thu, Jan 30, 2014 at 3:31:03 PM
Revit 2010 family parameters formula and room tag
Fri, Aug 7, 2009 at 4:28:34 PM
Partial Label Annotation
Mon, Apr 20, 2015 at 10:14:20 AM
Page generation time: 0.0693
