Forums >> Revit Structure >> Technical Support >> Wall footing - breaks at inserts
Fri, Mar 20, 2009 at 9:25:54 AM | Wall footing - breaks at inserts
minfante
Anyone know why my wall footings breaks when an opening extends down to the bottom of the host wall.  I tried both check and unchecked for the type parameter.  Always breaks.
Fri, Mar 20, 2009 at 9:56:35 AM | Wall footing - breaks at inserts
mholzer
4 Stars: 1 Votes
This has happened to me and the wall footing will jump to the top of the opening thinking that the wall is simply stepping up.  To keep the footing from breaking I extended the opening to just above the bottom of the wall.
Fri, Mar 20, 2009 at 10:01:20 AM | Wall footing - breaks at inserts
minfante
Thanks for the response.
Fri, Nov 20, 2009 at 12:41:58 PM | Wall footing - breaks at inserts
BigD
BigD Avatar
1 Stars: 1 Votes
ok . . . I'm having this same problem.  I copy/monitored the architect's walls into my structural model.  Of course the door openings came with the walls and are also monitored.  the sill elevation for the door openings is at 0'-0" (same as FFE).  And my wall footings are breaking at either side of the door opening IN SPITE of having the appropriate type parameter checked.  And the former solution DOES WORK, but this is a large building with loads of doors.  Surely there's a better solution.  What causes this?
Fri, Nov 20, 2009 at 2:42:59 PM | Wall footing - breaks at inserts
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
It's a copy / monitor issue with the openings.
I usually uncheck the opening option in the copy / monitor dialog...then place my own openings.
I stop monitoring, place my openings, then continue monitoring my walls to theirs...this way Revit will track their openings to my wall and if they move a door I get notified.
The issue is with how Revit is generating the openings that get created during the copy / monitor command.
Revit generates the copied opening using the wall opening command insead of using the door command.
To test this, draw a wall and place a "door" in revit strucure. Then, on the same wall, draw an opening using the wall opening command. Then add your footing and you should get a result similar to what you are describing.
Edited on: Fri, Nov 20, 2009 at 2:51:31 PM
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Nov 20, 2009 at 2:59:04 PM | Wall footing - breaks at inserts
BigD
BigD Avatar
1 Stars: 1 Votes
THANK YOU!  That was brilliant!  I'm going to have a TON of work to do. Smile
Fri, Nov 20, 2009 at 3:00:40 PM | Wall footing - breaks at inserts
brettgoodchild
4 Stars: 17 Votes
Glad I could help you out.
At least now you know for the future to avoid rework.
We'll just call it a Revit "feature"
Great program, just has its little quirks about it.
                             ~ Abraham Lincoln
Fri, Nov 20, 2009 at 3:24:56 PM | Wall footing - breaks at inserts
BigD
BigD Avatar
1 Stars: 1 Votes
ok, so I can delete the existing opening (brought in with copy/monitor) and then insert my own door opening (which is a cool family that I created with lintel that I can tag and schedule).  Will that opening be monitored so that if they move theirs (and they will), I'll be notified?
Or, do I have to turn monitoring off for the wall, then delete their wall opening, then insert mine, and THEN turn monitoring back on for the wall?  Is that what you're saying?
Fri, Nov 20, 2009 at 3:40:01 PM | Wall footing - breaks at inserts
brettgoodchild
4 Stars: 17 Votes
I would make a test file for this so you can get a process written down.
I have seen it not work when I have stopped the monitor process after the openings are placed as well as before.
Somedays it seems to be a crap shoot.
                             ~ Abraham Lincoln
Tue, Dec 1, 2009 at 10:48:18 AM | Wall footing - breaks at inserts
JohnnyMHP
I have a question about Walls, not sure if this is a good place to ask but I dont know where to start. Im trying to draw two 8" concrete walls on the same grid line but with an inch gap. For some reason Revit auto conects the two but I don't need them connected to eachother! Is there a setting to turn this off? Thanks.
Tue, Dec 1, 2009 at 10:53:26 AM | Wall footing - breaks at inserts
brettgoodchild
4 Stars: 17 Votes
If you don't want the autojoin, you can turn it off by right clicking on the walls grip and picking dissallow join from the shortcut menu.
Other wise, you can split the wall with a gap.
                             ~ Abraham Lincoln
Tue, Dec 1, 2009 at 11:24:05 AM | Wall footing - breaks at inserts
JohnnyMHP
Tue, Dec 1, 2009 at 11:36:01 AM | Wall footing - breaks at inserts
#13
Right click on the end of the wall and turn off wall join function.
Tue, Dec 1, 2009 at 11:48:20 AM | Wall footing - breaks at inserts
#14
JohnnyMHP
Good Child It worked on Revit Arch 2009... But it doesn't seem to work on 2010!
Tue, Dec 1, 2009 at 11:54:53 AM | Wall footing - breaks at inserts
#15
JohnnyMHP
WWHUB & GOODCHILD Thanks I figured it out!
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:58:50 PM
lower interior footing to match foundation wall footing
Tue, Mar 5, 2019 at 3:06:52 PM
Wall profile footing issure
Fri, Oct 3, 2014 at 7:06:49 AM
Double footing problem - plz help??
Thu, Nov 15, 2012 at 3:24:50 PM
Page generation time: 0.8327
