15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Room Schedule
6 Posts No Rating |
Hii I want to make schedule according to rooms like I want a schedule which has room name,floor finish,ceiling finish,wall finish & their Area. I've made from Schedule & quantity but it makes blank schedule.If I am missing something or there is any other way to make it.plese tell.
Revit can't read your mind, it will only schedule what you tell it t. If what you want is not there, then you haven't defined it yet. In Revit, variables like room finishes are called parameters. Some parameters are used to control elements and can not be scheduled. To schedule a parameter, it must be shared. This is a simple process once you learn it. Start by using your H E L P using parameters as your search. Here are some topics you should start with: Custom Parameters Creating New Parameters Shared ParametersCreating Shared Project Parameters Creating a Multi-Category Schedule In addition, there are tutorials that come along with Revit and also in some of the resources links here on the RevitCITY site. After you have spent some time with these, come back if you have additional questions.
Find a specific room in the room schedule |
Thu, Jul 4, 2019 at 2:08:03 AM
Embedded window schedule in Room schedule |
Thu, Nov 19, 2015 at 1:03:49 AM
automating door schedule ( From room # To Room #) |
Thu, Jun 20, 2019 at 2:14:07 PM
Room finish Schedule showing Deleted Rooms |
Wed, Aug 26, 2009 at 3:56:37 PM
Room names Not showing in Schedule [ 1 2 ] |
Tue, Jul 24, 2012 at 7:05:38 AM
20
