Forums >> Revit Building >> Technical Support >> Little roof help?
Thu, Mar 19, 2009 at 8:32:32 PM | Little roof help?
vanderloo
Some of you may recognize this from an earlier post. I kind of set it aside till now and am trying to figure this out and not having much luck. In the first screen shot you see the little gable at the highest ridge that I can't seem to figure out how to hip down to main ridge. Screen shot 2 shows the roof as it now appears in plan view. Screen shot 3 shows, in red outlines, what it should look like. Sorry I know this is obvious to everyone. Can someone tell me how to get the desired results. I have a tutorial which someone sent earlier that says select the roof and choose "Add Ridges & Valleys" button on the options bar. I do get those buttons when selecting some roofs but, for whatever reason, not this one.
Thank You in Advance.
Fri, Mar 20, 2009 at 4:52:34 AM | Little roof help?
MikeChan
3 Stars: 5 Votes
Have you done a search in the Revit help yet? I think that will explain alot.
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Additional Roof will not attach to original roof
Fri, Jun 7, 2013 at 7:56:40 AM
problemed roof
Fri, Mar 23, 2007 at 5:12:30 PM
Roof problems!
Sun, Feb 1, 2004 at 7:26:42 PM
Joining a conical roof to a gable roof or other rectangular roof
Tue, May 28, 2013 at 9:29:25 AM
Page generation time: 0.2597
