Forums >> Community >> The Studio >> Making Drafting Lines Non-Printable
Tue, Jun 28, 2005 at 5:15:40 PM | Making Drafting Lines Non-Printable
Rocky
I would like to make a drafting line non-printable, but still be able to see it on screen as part of construction lines. Reference planes wiil not work for what I am doing. Any help would be great.
Wed, Jun 29, 2005 at 1:55:10 AM | RE: Making Drafting Lines Non-Printable
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Will white lines work?
Wed, Jun 29, 2005 at 10:41:22 AM | RE: Making Drafting Lines Non-Printable
Rocky
I don't know if white lines will work. I need to use it as a reference line. I have a curved house and my drafting line is marking the arc of that curve at the midpoint. I use this line as reference as I build the rest of the house. Reference planes obviously will not curve, and I don't want to have to turn off the visibility of that line everytime I plot. What would be great is if there is a toggle or property that I can set this reference line to be a non-printable.
Wed, Jun 29, 2005 at 10:47:19 AM | RE: Making Drafting Lines Non-Printable
TomDorner
4.5 Stars: 25 Votes
Have you tried using a grid line? They will curve and since you can align and lock elements to them they can be very useful even in residential construction. While I don't do residential at work, I dabble in it at home with Revit and I use grid lines to define the exterior boundries of the house and align and lock my walls to them. Rather than having to turn them off each time you plot, you could have one view with the grids on and anothr to plot with them off. The view with the grids on becomes your "working view" HTH Tom
Non Printable Text
Mon, May 12, 2008 at 12:33:24 PM
Non Printable Text
Tue, Apr 15, 2008 at 9:23:18 AM
Non-Printable Text for Office Notes
Fri, Sep 28, 2007 at 11:08:44 AM
Non Printable Text
Fri, Feb 20, 2009 at 9:22:46 AM
Model Lines
Wed, Apr 27, 2005 at 6:49:12 PM
Page generation time: 1.7233
