Forums >> Revit Building >> Technical Support >> Black 3D objects
Thu, Mar 19, 2009 at 3:31:06 PM | Black 3D objects
dropem
dropem Avatar
has anyone had a problem with objects in 3d being black?  they look good in a 3D View but not in regular 3D.  they render fine but i cant add textures to misc. spots because i cant see them.   Everything that is linked to the drawings also look good but as soon as i draw something in the model itself its black.
Fri, Mar 20, 2009 at 8:05:38 AM | Black 3D objects
tim123
4 Stars: 19 Votes
Can you attach a screenshot of the problem?  It may just be the density of the surface pattern.
Tue, Nov 3, 2009 at 3:43:52 PM | Black 3D objects
ahartCA
did you ever get an answer?
i'm having the same problem, posted a photo and description here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=18380
Black square behind RPC Objects
Fri, Jul 20, 2007 at 2:49:34 PM
3D view Painted Black
Wed, Nov 4, 2009 at 9:22:38 AM
Start and End of objects.
Thu, Jul 14, 2011 at 11:11:26 AM
Assigning Materials to 3D objects made with the command “Modelling-Create...”
Fri, Jun 3, 2011 at 5:57:50 PM
Black annotations on black screen
Mon, Jun 20, 2016 at 2:18:39 PM
Page generation time: 0.7509
