Forums >> General Discussion >> Wishlist >> Rigid Insulation
Tue, Jun 28, 2005 at 8:48:32 AM | Rigid Insulation
VF1Stampede
3 Stars: 2 Votes
Hello, I'm looking for a way to put rigid insulation into my revit drawings. I can only seem to find tapered insulation in the Revit libraries. If anyone has used rigid insulation in their projects, and could help me out, I would appreciate it.
Thu, Jan 10, 2008 at 8:33:53 AM | Rigid Insulation
PMARSHALL
I assume that you're referring to adding rigid insulation within your wall system, and I don't think using a family is the way to go about this. If I have understood you correctly, then all you have to do is to edit the structure of your wall system. (Under the Construction section click on the <edit> button). Once there, under function, choose thermal/air layer [3], under material choose Insulation/Thermal Barriers - Rigid Insulation. (If it's not already there use the duplicate key and rename the new material you create to 'Rigid Insulation'.) Then just enter your thickness of rigid insulation you want in the wall.
Rigid Insulation
Fri, Mar 23, 2007 at 2:48:21 AM
Slab Rigid Insulation
Wed, Nov 21, 2007 at 7:49:37 AM
two-way tapered rigid insulation
Mon, Feb 5, 2007 at 4:17:25 PM
complex roof - help!
Wed, Feb 27, 2008 at 11:57:23 AM
several keynotes on one object r2016
Thu, Aug 31, 2017 at 6:50:28 AM
Page generation time: 1.3993
