Forums >> Revit Building >> Technical Support >> CMU HATCH - ALTERNATING 8" AND 4" BLOCK
Wed, Mar 18, 2009 at 7:06:05 PM | CMU HATCH - ALTERNATING 8" AND 4" BLOCK
bigworm917
Does anyone have a .pat file or the code to make a pattern that looks like a CMU wall which has alternating rows of 8" block and 4" block? I am having trouble making one. Thanks!
Tara
Fri, Mar 20, 2009 at 5:25:39 AM | CMU HATCH - ALTERNATING 8" AND 4" BLOCK
tim123
4 Stars: 19 Votes
I have attached an explanation showing how the fill pattern definitions work, although it's in metric.  Change the 100 to 4 inches, 200 to 8 inches, 300 to 12 inches, the 450 to the length of your block and the 225 to half the length of your block.  Your pattern should then work.
Small correction to the PDF - the spaces need to be negative. Corrected version attached.
Edited on: Fri, Mar 20, 2009 at 7:48:05 AM
Fri, Mar 20, 2009 at 10:05:41 AM | CMU HATCH - ALTERNATING 8" AND 4" BLOCK
bigworm917
Thank you very much! This explains how to make patterns alot better than other tutorials I have seen.
Wed, Sep 23, 2009 at 3:51:47 PM | CMU HATCH - ALTERNATING 8" AND 4" BLOCK
HGL5
THat is a good tutorial... very well done
Wed, Sep 23, 2009 at 4:03:33 PM | CMU HATCH - ALTERNATING 8" AND 4" BLOCK
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
NICE TIM!
J. Allen Ball
Alternating Course Hatch Pattern - Arch2008
Fri, Jan 11, 2008 at 11:05:56 AM
8"cmu wall and 6" cmu wall
Sun, Aug 9, 2009 at 10:49:28 AM
CMU Block Modules
Sun, Sep 12, 2010 at 12:23:36 PM
CMU Block pattern problem (2010)
Wed, Sep 9, 2009 at 2:31:27 PM
Hatch Pattern Scale Question
Thu, Jun 17, 2010 at 8:31:12 AM
Page generation time: 1.3522
