21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Double footing problem - plz help??
1 Posts No Rating |
Hi When I attach a bearing footing to my wall with the base extension of the inside layers at slab level and the rest of the wall at T.O footing level, 2 footings appear - 1 at the extension layer and one at the bottom of the wall where I need it to be. How do I get rid of the second footing? Thanks
41 Posts No Rating |
I have just come across this problem too. Does anyone know a solution? Adding finish layers to walls is great...until now. Obvisouly I don't want my gwb to extend down to footing.
Revit Architecture 2011
I split the wall horizontally at the floor line and use a foundation wall which doesn't have the interior finishes.
Double Footing |
Fri, Mar 13, 2015 at 9:51:11 AM
Strange problem !!! hlp plz |
Thu, May 29, 2008 at 4:14:42 PM
13
Problem when applying a footing to wall |
Thu, Aug 23, 2012 at 1:58:50 PM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
