Forums >> Revit Building >> Technical Support >> Infilling elements containing sweeps
Wed, Mar 18, 2009 at 3:49:20 PM | Infilling elements containing sweeps
jmerrick
I'm working on a renovation project and having trouble with demolition of doors and the infilling elements it produces.  When I delete the door I get an infilling element, not a problem.  Then I insert a new door in the same position so that I graphically have a door showing as demo'd on the Demolition Plan and a new door in its place on the Floor Plan.  My problem comes from the wall sweep built in to the wall type.  The wall has a 4'-0" wainscot of another material which someone else made a part of the wall type.  So when I put the new door in place of the demolished door the concrete block goes away but the wall sweep portion of the infill stays in place, I assume because it is technically a "sweep" and not a "wall".  Whatever the reason it is irritating as heck.  I can hide the infill item by element but then I'd have to do that in many place and it would inevitably get missed on some other sheet of the documents.
I know this is a long winded question to digest, but any ideas?
Wed, Mar 18, 2009 at 3:59:35 PM | Infilling elements containing sweeps
tim123
4 Stars: 19 Votes
Create the wainscot as part of the wall rather than as a sweep.  Create an extra layer in the wall and unlock its layer.  You can stretch this down to the correct level in a section.  You  could also try hosted sweeps rather than integral sweeps as these are easier to control.
Hide infilling lines
Mon, Aug 22, 2011 at 2:51:33 AM
Lineweight of demolished elements
Wed, Jul 9, 2008 at 7:23:17 PM
Cleaning Up Design Option Elements with Main Model Elements
Wed, Jun 17, 2015 at 1:38:27 PM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Page generation time: 4.3399
