10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> rendering decals
21 Posts No Rating |
When I bring a decal into my model the outline shows up, but it will not render. It is on the floor surface. Any suggestions?
Did you apply the decal in the right face of the floor??? Did you change the parameters (properties) of the Decal like "Transparency"???
You are probably trying to apply it to a split surface. The split surface overides the other surface finishes. You can cut a hole in the floor and fill it with the same floor type and apply the decal to that.
Thanks Tim183. That worked!
problem with rendering decals |
Mon, May 14, 2007 at 5:44:57 PM
Decals not Rendering in 2010/12 |
Wed, Jul 20, 2011 at 1:34:53 PM
problem rendering decals |
Tue, Aug 3, 2010 at 8:18:16 AM
Rendering Decals |
Fri, May 8, 2009 at 11:45:11 AM
Decals not showing.. |
Fri, Feb 16, 2018 at 9:39:04 AM
12
