21 Users Online (19 Members):
Forums >> Revit Systems >> Technical Support >> Merging Spaces?
53 Posts No Rating |
I have a room that is L shaped and for some reason when I create a space for the rooom it wants to make 2 separate spaces for that room. Is there a way to combine or merge spaces into 1? Just wondering,Ken@rlmrlm.com
If there are two spaces then you have placed something that tells Revit you have two spaces. Revit defines spaces from room bounding elements. The most common are walls set to be room bounding and room seperation lines. You must have one or the other between these two spaces. If it is a wall (maybe a low wall), turn off room bounding in its properties. Otherwise, make sure VG shows room boundries and look for one of those between your areas.
check for room separation lines in your link and your MEP model through VG (its a sub catagory of lines) making both space and room separation lines another color, and a wider line helps a lot.
Edited on: Tue, Feb 2, 2010 at 10:41:19 AM
20 Posts No Rating |
I have Two room divided by wall with huge opening. Revit interprate its as two rooms. But i want listet its as one room. Is it possible to merge two spaces?? - that is the question
As WWHub says, select the wall with the opening and in its properties uncheck roombounding. Be aware, when this wall is goin up to a higher level you'll ger the warning room is not in a enclosed area, you'll make this area enclosed with a room separation line.
8 Posts No Rating |
I'm coming! Let's see what happens _________________________________________ uggs ugg boots
1 Posts No Rating |
Awesome.. Thanks for the room bounding check off tip.
Revit Spaces Elec VS Mech |
Tue, Feb 2, 2010 at 10:50:50 AM
Merging Shared Parameters |
Mon, Jun 8, 2009 at 3:08:12 PM
Merging Toposurfaces |
Tue, Apr 21, 2015 at 8:07:53 AM
Beam not merging |
Mon, Mar 16, 2009 at 5:57:09 AM
dimension text format, remove extra spaces |
Tue, Aug 24, 2004 at 8:38:42 PM
