Forums >> Revit Structure >> Technical Support >> Metal deck roof profile
Wed, Mar 18, 2009 at 6:59:48 AM | Metal deck roof profile
bluedog1
bluedog1 Avatar
I have been trying to create a 1 1/2" metal deck roof  so when I cut a section I can see the roof profile. I have tried the following link w/o success http://revitfamilies.blogspot.com/
I created the profile using the profile template, then started the new family with the Structural Framing - Beams and Braces.rft. The profile is loaded, and I deleted the solid.
What am I supposed to draw with the sweep tool? Is there anything specific I have to do to orient the profile when I load it?
This is crucial to the architect to be able to see roof profile when they link our model to theirs
thanks for the help
bluedog
Wed, Mar 18, 2009 at 8:28:40 AM | Metal deck roof profile
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this it may help
http://revitfamilies.blogspot.com/2008/08/quantify-profiled-roof-sheeting.html
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 18, 2009 at 8:45:13 AM | Metal deck roof profile
bluedog1
bluedog1 Avatar
Thanks for the reply, but that is the link I was referencing. I think I need to get a clue on sweeps.
Thu, Mar 19, 2009 at 8:48:42 AM | Metal deck roof profile
bluedog1
bluedog1 Avatar
I have a workaround, just use a floor family instead of a roof.
Thu, Mar 19, 2009 at 10:13:29 AM | Metal deck roof profile
4 Stars: 205 Votes
Hi "Bluedog1", I did several videos about this same question a few months ago, if you search you can find it...
Use the Roof>Sloped Glazing system and it work fine....
Thu, May 12, 2011 at 2:35:27 PM | Metal deck roof profile
juststarting
bump
I too am stuck on the same spot .
"I created the profile using the profile template, then started the new family with the Structural Framing - Beams and Braces.rft. The profile is loaded, and I deleted the solid.
What am I supposed to draw with the sweep tool?"
Fri, May 13, 2011 at 1:05:51 PM | Metal deck roof profile
4 Stars: 205 Votes
Maybe this can help you, watch the video i post there.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=22937&start=0
Metal Deck profile question
Thu, Jun 1, 2017 at 11:16:20 PM
Metal Structural Deck on Floor
Tue, Jul 12, 2005 at 10:06:29 AM
metal deck cut profile
Thu, Nov 4, 2010 at 9:17:43 AM
creating a corregated metal roof
Mon, Oct 1, 2012 at 1:20:26 PM
Metal roof deck on sloped roof
Wed, Oct 21, 2009 at 3:33:17 PM
Page generation time: 0.4551
