Forums >> Revit Building >> Technical Support >> Help opening older version of Revit file
Wed, Mar 18, 2009 at 12:14:37 AM | Help opening older version of Revit file
cadviz
Hi,
I've tried serching for this in the forum but I only kept on coming across people trying to open newer files on older versions. BUT in my case I want to open an older version (I have no clue in what version it was created) and I have tried it on Revit 9.1, and 2009, but can't get it to open.
Shouldn't it be like word if you have 07 you can open 97-03 but if you have 97-03 you can't open 07????
I would really appreciate it since this projects bids in a couple of days and need it to help my estimator for his take off...
 thanks,
-cadviz
If plans & specs don't match, it equals a shitty project.
CADVIZ
Wed, Mar 18, 2009 at 12:50:34 AM | Help opening older version of Revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I assume you are getting errors such as "your project needs to be manually upgraded"?  How large is the file?  If its small, then as the error message suggests file a Support Request with Autodesk and they should be able to update it fairly quickly for you.
If its quite large you might just need a computer with sufficient RAM to be able to upgrade it as upgrading is very RAM intensive. A 100MB file can typically require 2-4GB RAM to update...
HTH.
Regards,
Chris.
Wed, Mar 18, 2009 at 1:06:41 AM | Help opening older version of Revit file
cadviz
Mr Spot,
thanks for the support... you can dis-regard my question, i just figured it out....
thank you very much!
-cadviz
CADVIZ
Wed, Mar 18, 2009 at 8:36:03 AM | cadviz
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting cadviz from 2009-03-18 01:06:41
Mr Spot,
-cadviz
if you think that what you found out is something that other users may benefit from, could you please post the soluition.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 18, 2009 at 11:55:48 AM | Help opening older version of Revit file
cadviz
 it was just a dumb question on my behalf... turns out it was a newer version[[I was thinking I was sitting in the computer running 09 where I would be up tp date with no issues) I was actually trying to open it in  2008 and 9.1 then I realized HEY! let me try it on the other computer (which runs Revit Architecture 2009) and it worked
 so we're gonna have to update real soon to avoid any issues down the road.
CADVIZ
Opening File
Mon, Apr 24, 2006 at 9:21:33 PM
Saving
Sat, Jan 20, 2007 at 11:55:53 AM
Are people still using older versions of Revit?
Sat, Aug 29, 2015 at 12:49:17 AM
Origin of the word Revit? And how do "save as" to older version of Revit?
Thu, Sep 11, 2014 at 2:20:30 AM
Going from a Revit 2012 file to an older version of Revit
Thu, May 26, 2011 at 11:58:53 AM
Page generation time: 1.6338
