Forums >> Community >> Newbies >> revit material
Tue, Mar 17, 2009 at 10:48:26 PM | revit material
05architect
2.5 Stars: 2 Votes
hi there, im new to revit, i want a new material for my list of materials in revit, the question is how can i put a new material to the existing revit mateials, thanks, hope 2 learn more revit...
Wed, Mar 18, 2009 at 12:41:41 AM | revit material
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It depends on which list you are trying to add to.
The "Render Appearance Library" is read only and cannot be added to.
The Settings-->Materials can be edited as much as you want.
Simply set the base material from the render appearance library that is closest to what you need, then edit it as needed to appear as you need it to.
I suggest you check the help file for starters and the Rendering presentation on my blog as this is a little tricky for newbies...
Regards,
Chris.
Revit 2013 Material User Interface
Thu, May 2, 2013 at 4:50:53 PM
Material troubles when duplicating a material
Mon, Dec 12, 2016 at 8:47:07 PM
Revit 2013 Material Creation
Fri, Mar 15, 2013 at 3:35:40 PM
How do you add an imported material to Revit's material library ?
Mon, Aug 16, 2010 at 8:06:17 AM
Revit 2012 - material tag "question marks" everywhere
Wed, Sep 13, 2017 at 9:26:13 PM
13
Page generation time: 1.5644
