Forums >> Revit Building >> Technical Support >> missing legend components
Tue, Mar 17, 2009 at 8:14:39 PM | missing legend components
tarahdb
I am trying to create a legend, but none of the in-place families that I created using the "create" button on the modelling tab shows up in the list of available families when I click "legend component". Imported families work fine. In fact, if I start a new family outside of the project, copy the in-place family to that new family, and import the new family into the project, it shows up fine in the legend components list. Do I need to create families outside of my project in order for them to show up as legend components, or is this problem due to a program bug or a setting I have incorrect?
Wed, Mar 18, 2009 at 12:31:34 AM | missing legend components
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In-place families should be used sparingly to say the least.  They are for one off pieces that for whatever reason are difficult to model outside of the model.
If you are needing to show legend components of them then there is a good chance you've repeated them around your model and as such should be modelled as normal families.
HTH.
Regards,
Chris.
VIEWING LEGEND COMPONENTS PROPERLY
Tue, Apr 14, 2009 at 10:04:02 AM
Legend Components
Thu, Aug 12, 2010 at 2:00:15 PM
Curtain Wall Door as Legend Components
Mon, May 19, 2014 at 7:55:50 PM
Elevation tag missing in Symbol Legend
Tue, Nov 21, 2006 at 1:18:43 PM
best practices for wall type sheet
Tue, Dec 8, 2009 at 9:44:48 PM
Page generation time: 0.1725
