Forums >> Revit Building >> Technical Support >> Miter Curtain Wall Border Mullions
Tue, Mar 17, 2009 at 3:16:24 PM | Miter Curtain Wall Border Mullions
corrinna
Hi there. I've made a new capless curtain wall system (panels & mullions) but the corners of the border mullions around the glass look bad. Is there a way to miter these? I've attached a picture to further explain. Thanks!
Tue, Mar 17, 2009 at 5:55:53 PM | Miter Curtain Wall Border Mullions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Currently there is no way to mitre curtain wall mullions...  Add to the wishlist.
Regards,
Chris.
Wed, Mar 18, 2009 at 8:10:58 AM | Miter Curtain Wall Border Mullions
corrinna
Thanks Chris. That's too bad. Is there a way to edit the extrusion length of mullions, not just the profile? maybe  I can stick a custom corner peice in there? Or am I wasting my time? Cheers, Corrinna
Wed, Apr 21, 2010 at 3:04:57 PM | Miter Curtain Wall Border Mullions
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
I just downloaded 2011.
Upgraded a project.
Still no mullion mitering.
The only two options are "make continuous" and "break at join" - the same crude options from previous releases.
trimming vertical mullions to continuous border mullion
Tue, Aug 13, 2013 at 5:28:05 PM
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:31 PM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:15 AM
Mitering curtain wall panels
Wed, Dec 26, 2007 at 9:11:55 AM
Curtain wall corners
Sat, Apr 5, 2008 at 12:45:04 AM
Page generation time: 0.6406
