Forums >> Revit Building >> Technical Support >> can't change roof pitch
Tue, Mar 17, 2009 at 1:12:54 PM | can't change roof pitch
vanderloo
Hi All,I have a nearly completed residential project with a semi complex hip roof with a 6:12 pitch. The client just called me and asked me to change the pitch to 6 1/2:12. I thought I could just select the roof(s) either all together or one at a time and just change the pitch in properties and be done with it. I've tried both ways and I get an error every time that "the roof cannot be joined" when I select "unjoin elements" I get "Can't make roof footprint." The footprint shouldn't change with a pitch change?? I thought this was supposed to be one of the great benefits of BIM. Easy to make changes and changes made in one view are effected in all views. Anyway, is there an easy way to do this or do I have to give my client CPR when he gets the bill for my time for re-drawing the entire roof?Thanks,Phil
Tue, Mar 17, 2009 at 4:14:29 PM | can't change roof pitch
4 Stars: 205 Votes
The problem with the "join/Unjoin roof" is here like yyou can see in the images attached...
Wed, Mar 18, 2009 at 9:47:54 AM | can't change roof pitch
vanderloo
Ya, That's an area that  I haven't gotten into fixing yet but I drew it correctly in the roof plan using detail lines. I have a little tutorial about adding that missing peice but haven't dug into it yet. This is my first project since switching from ACA and I'm just taking it one step at a time. I have been advised in other forums though, that the join/unjoin roof command is probably causing the problem. Thank You for your input and I will look into it.
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:50 AM
Duel Pitch Roof
Tue, Feb 10, 2009 at 2:11:10 PM
Roof Pitch Change
Wed, Feb 1, 2006 at 11:46:21 AM
Defult roof Pitch ?
Wed, Jul 27, 2011 at 6:03:21 PM
Bay window roof pitch
Fri, Apr 7, 2006 at 1:01:50 PM
Page generation time: 1.6961
