19 Users Online (17 Members):
Forums >> Revit Building >> Tips & Tricks >> steel stair stringers under treads
here in brisbane australia, we use prefabricated steel stringers on houses, on which timber or concrete treads are bolted. for all those other aussies maybe trying to figure it out - here is a way to do it. for open tread stairs on 100x50 rhs stringers. rhs means rectangular hollow section.
open a stair family. the usual edit/new and duplicate. make the stringers wood, stringers metal. right and left stringers - open. middle stringer, leave as 0. (but by making this 1, and left/right stringers 'none', you get a centre stringer).
stringer thickness 50. stringer height 100.
open stringer offset, 150 say. this moves the stringers in 150 from tread outer edges, but only if stringers are set to 'open'.
stringer carriage height 100.
and boom - rhs stringers emerge!
hope this helps other new users of revit.
stair stringer control question |
Tue, Oct 2, 2007 at 9:56:28 PM
Stairs - steel & precast conc treads |
Mon, Dec 20, 2004 at 12:46:06 AM
Lineweight Tool Does Not Function For Stair Stringers.... |
Mon, Oct 24, 2016 at 4:23:49 PM
Steel Stairs with Channel Stringers |
Wed, Jun 7, 2006 at 11:33:30 AM
stair stringers |
Fri, Jun 27, 2008 at 3:12:38 PM
