Forums >> Revit Building >> Technical Support >> how are joined beams and floors in 3d view?
Mon, Jun 27, 2005 at 4:24:04 AM | how are joined beams and floors in 3d view?
arslan57
I created floors, beames and colomuns there isn't a problem in plan view.But in the 3d view I don't wan't to see joined lives. There are visible edge between beams and floors. The join geometry command isn't cleaned these in the 3d view. Please help me.
Mon, Jun 27, 2005 at 4:35:40 AM | RE: how are joined beams and floors in 3d view?
rogern
use the linework tool
Mon, Jun 27, 2005 at 4:51:29 AM | RE:
arslan57
Quoting rogern - 2005-06-27 04:35:40
"use the linework tool"
Is there a different solution of this problem ?
Mon, Jun 27, 2005 at 6:11:00 AM | RE: how are joined beams and floors in 3d view?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In most cases providing the materials are the same you shouldn't see any join line... If the materials aren't the same, unjoin, then swap material and rejoin.
Mon, Jun 27, 2005 at 6:54:40 AM | RE: how are joined beams and floors in 3d view?
arslan57
Thank you very much.
Joining beams to walls and floors
Thu, Jan 15, 2009 at 9:00:36 AM
How to see the upper floor (beams,floors) in plan view?
Tue, Jun 14, 2005 at 4:37:20 AM
Tagging for floors between beams
Tue, Jan 31, 2012 at 5:23:10 PM
Auto Join Concrete Column & Beams
Thu, Jul 1, 2010 at 2:08:30 AM
Beams connections - "soft", not sharp
Fri, Dec 7, 2012 at 9:06:42 AM
Page generation time: 1.7610
