18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Prefix to spot elevation!
56 Posts No Rating |
HI,Please refer the attached image; i need to add TOW as a prefix to spot elevation. I did this by adding TOW as a symbol but i have to create for different directions so that i can use 4 sides of my building/plan. Can anyone tell me do this in better way!Thank you
When you place a spot elevation, you can click on its properties and you can set a prefix or suffix to the value.
sorry i could not found anything like that
Here is a screen shot.... Element properties.
Revit Strucure 2009 spot elevation problems |
Fri, Jul 25, 2008 at 11:48:29 AM
Spot Elevation vs. Level elevation |
Tue, Aug 19, 2025 at 1:06:15 AM
Elevation marker prefix |
Thu, Jun 11, 2009 at 4:46:20 PM
Spot Elevation Suffix Under tag |
Fri, Mar 5, 2010 at 10:13:04 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
