20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Tag issue in floor plans
56 Posts No Rating |
hi, i am using revit 2009 and i searched in this forum about this topic, but no results. 1. Can we place ceiling heights in floor plan?2. Can we place Structural slab level and finished floor level in floor plan as one tag? push
"Can we place ceiling heights in floor plan?" - Use "Spot Elevations"
hi typhoon spot elevations reads only the floor slab level @ floor plan...........more over as i said before i need to show structural slab level and finished floor level in floor plan with suffix SSL and FFL respectively...................how to acheive this?
No, if you have a ceiling in your project, open the "Ceiling Plan" then you can apply the spot elevation to that ceiling...
YES typhoon, I ts working properly in ceiling plan but we need to show that height in floor plan.............any tips?
Revit has to be able to "see" the element in order to tag it. In other words, it has to be within the view. Obviously, your ceiling is not in the view. But... you could be creative and add a tiny plan region.
Door tags linked to floor plans |
Tue, May 3, 2005 at 6:17:50 AM
Room Tag Missing in Copies & Callouts of Floor Plans |
Mon, Dec 10, 2007 at 11:55:32 AM
Enlarge Floor Plans |
Thu, Feb 12, 2009 at 4:12:21 PM
12
Best Software to Create Presentation Floor Plans |
Fri, Apr 30, 2010 at 12:56:47 AM
Using Area Plans as Main Floor and Unit Layout plans |
Mon, Mar 29, 2021 at 1:59:33 PM
