29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Steel Joists
RAC 2009 i see the length of the 20K4 steel joist in its properties- but it's grayed out and i couldn't find how to change it.. but i was thinking- is it possible that since these joists are pre-made that we are not supposed to change their length but rather change something else to accommodate them?
You can change the length by selecting it and changing the temporary dimension, or drag the points.
thanks tim.. i just kept working with dragging the ends like you said and it finally worked.. do you know if we are really supposed to change the length of these steel joists? isn't their length specified at the factory? or do we order custom lenghts that vary around a standard length/type? and the default position is to embed the seat half way into a block wall at the top with the top of the joist flush with the top of the wall.. is that the standard way to do it? or would they put the seat up against the wall at the top with a bracket bolted to the wall up under the seat?
actually i can only drag the end real close to the wall- but if it touches the wall it will snap to the center of the wall.. is there a way to turn off that snapping? i looked at every part of element properties for something like that..
using steel bearers and joists ? |
Mon, Jul 4, 2011 at 7:12:02 PM
Family Needed - Top Chord Offsed Double Pitched Underslung Steel Joists |
Tue, May 18, 2010 at 11:40:49 AM
timber and steel to have different detail levels |
Fri, Sep 3, 2010 at 8:29:04 AM
2D Open Web Joists in Section View |
Mon, Aug 27, 2012 at 1:07:56 PM
Curved steel joists |
Tue, Nov 3, 2009 at 3:51:48 PM
