Forums >> Revit Building >> Technical Support >> Materials on masses are being applied to all my masses...HELP!?
Sat, Mar 14, 2009 at 11:17:40 AM | Materials on masses are being applied to all my masses...HELP!?
MISSPSYCHO
When I changed the materials properties of one mass (Structural), it applied the same material to other masses (Food service equipment-completely different components). Please help
Sat, Mar 14, 2009 at 11:32:15 AM | Materials on masses are being applied to all my masses...HELP!?
tim123
4 Stars: 19 Votes
When you changed the materials for the mass (Default Mass), you changed the properties for all elements with the material 'Mass'.  You need to duplicate it and create a new material for it
Sat, Mar 14, 2009 at 1:39:17 PM | Materials on masses are being applied to all my masses...HELP!?
4 Stars: 205 Votes
yeap...
Sat, Mar 14, 2009 at 1:53:00 PM | Materials on masses are being applied to all my masses...HELP!?
MISSPSYCHO
Thanks, but that isn't working. ANy other suggestions? It's also happening with ceiling, topography, and flooring materials.
Sat, Mar 14, 2009 at 1:58:58 PM | Materials on masses are being applied to all my masses...HELP!?
4 Stars: 205 Votes
Like Tim123 said, you must duplicate the material with other name, then you can change the "texture" (material) in that object and don't affect the other objects....
Compare Two Masses in Schedule
Fri, Jan 15, 2016 at 3:24:28 PM
Masses Don't Print?!?
Thu, Feb 24, 2011 at 2:47:51 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Move/Copy/Align Masses
Thu, Jan 10, 2013 at 8:44:30 AM
triangulate masses
Sat, Dec 12, 2015 at 12:59:30 PM
Page generation time: 1.6884
