Forums >> Revit Systems >> Technical Support >> Yet another family parameter question.....
Fri, Mar 13, 2009 at 1:27:55 PM | Yet another family parameter question.....
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
Id like to apply a toggle/drop down or possibly even a lookup table to a piece of mechanical equipment:
I would like to give the user a set of voltage choices based on what the equipment is available in - 120;270;480 and not allow them to use a voltage that is not available, this also applies to many other mechanical parameters, voltage is just being used as an example.
Fri, Mar 13, 2009 at 2:04:46 PM | Yet another family parameter question.....
Why not just do this with type catalogs.
Fri, Mar 13, 2009 at 2:15:34 PM | Yet another family parameter question.....
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
by type catalog are you refering to a family type? If so, Id like my terminal boxes (and other mech equip) family types based on the unit size not the voltage, and allow the electrical department to choose from the voltages that the equipment is available in later when they are circuiting and balancing loads.
 If I have a type catalog is something other than the above, could you expand on what it is exactly?
Fri, Mar 13, 2009 at 2:30:15 PM | Yet another family parameter question.....
Read your help on type catalogs
Fri, Mar 13, 2009 at 2:43:31 PM | Yet another family parameter question.....
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
This is awesome!!!! The whole department is a buzz! We will be revising many of our existing families, and the world of revit has gotten a little friendlier Smile
I found this link below by searching on the term "type catalog" which could be useful for anyone who reads this post in the future:
http://whosafraidofthebigbadbim.blogspot.com/2009/03/revit-type-catalog-tip.html
NOT Parameter Formula Question
Fri, Apr 10, 2009 at 8:30:17 AM
Applying a Family Parameter
Tue, May 1, 2007 at 6:16:48 AM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
Custom Type of Parameter in Family Editor
Thu, May 14, 2015 at 3:03:40 PM
Revit family visibility parameter question (Revit 2011)
Thu, Jun 9, 2011 at 10:57:25 AM
Page generation time: 2.0473
