Forums >> Community >> The Studio >> Importing Miscorosft Office Documents?
Fri, Jun 24, 2005 at 7:40:09 PM | Importing Miscorosft Office Documents?
Robb
Can Revit import MS Office documents such as Word and Excel? If so please describe how well Revit handles imoprting these files and if it has the ability to link to these types of files. I know earlier releases of ACAD you could import excel and word docs but only a certian amount of rows and column in excel. Want to know if Revit can do this. Thanks.
Fri, Jun 24, 2005 at 9:29:09 PM | RE: Importing Miscorosft Office Documents?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Word documents are easy. Simply select all the text in the word doc and copy to clipboard. Then start a new text box in revit and paste into it. Excel docs are a little more tricky. Two methods: Make a jpg file of the spreadsheet and import in as an image. Or link the excel spreadsheet into an ACAD file and then link the ACAD file into revit... This method will retain some automation... HTH.
Fri, Jul 15, 2005 at 4:50:05 AM | RE: Importing Miscorosft Office Documents?
rockdraft
We use "Snag-it" to cut and paste from Excel.
Fri, Sep 28, 2007 at 1:58:21 PM | Importing Miscorosft Office Documents?
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
You say that Word documents are easy, but I've had problems in the past with them. If I remember right I had a document that had two columns separated by tabs. When it pastes in everything is misaligned. You can zoom in and realign it, but if you zoom out and it re-misaligns somethings. I had to raise my voice in the office to the guy that was repeatedly zooming in, fixing it, zooming out, zooming in, fixing it, zooming out...I told him the definition of crazy was doing the same thing over and over expecting a different result, but that didn't stop him. I threatened to remove all of his projects from his job-list so that he could spend rest of the week trying to get the text aligned. Eventually, I leaned over, deleted the whole text box, saved to central and closed Revit.
Wed, Nov 14, 2007 at 4:00:51 PM | Importing Miscorosft Office Documents?
JFosterIII
JFosterIII Avatar
I tried linking the Excel spreadsheet to ACAD and then importing the DWG into Revit, but Revit said that it couldn't link all elements and did nothing. Does it matter how you link the Excel spreadsheet to ACAD?
Wed, Nov 14, 2007 at 4:07:01 PM | Importing Miscorosft Office Documents?
JFosterIII
JFosterIII Avatar
And as a side note...didn't we pay enough for this program and all that came with it to expect to have the ability to do something so basic as to import any of the Microsoft Office products?  Or even to have a decent text editing function?? Based upon the number of comments and questions regarding this subject, it seems to me that it has more than enough merit to the end user.
Importing MS Word (or other text) into Revit
Thu, Jul 31, 2014 at 8:48:35 AM
11
Appearance of drawing issue sheets
Tue, Dec 2, 2014 at 9:19:20 AM
What to do when an office you are working with is using an older version
Tue, Jul 1, 2008 at 4:40:20 PM
Construction Documents - Architectural
Sun, Jan 8, 2006 at 10:37:43 PM
Architecture - interior designer template
Tue, Mar 12, 2019 at 4:36:16 PM
Page generation time: 0.6641
