Forums >> General Discussion >> Revit Project Management >> Revit - ADT in NavisWorks
Fri, Mar 13, 2009 at 9:59:16 AM | Revit - ADT in NavisWorks
tchuparkoff
I am doing a project that will envolve the Architecture in Revit and MEP in ADT, and I want to use NavisWorks to review these two seperate models.....here's the question....Where can I find a NavisWorks Tutorial?  I have looked and I can'r seem to find any good ones?
 Thoughts,
Thom Chuparkoff
Orlando
Mon, Mar 16, 2009 at 2:20:20 PM | Revit - ADT in NavisWorks
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
just to make you sure your right on this, the mep is going to be done in architectural desktop? there really arent any good navis tutorials and generally it is because its a pretty intuitive program, the users guide would probably help which should be installed with the program, what version do you have jetstream 5.4 or manage 09? you are unable to do the clash detection which i am assuming is your end goal with any of the other versions unless you have manage 2010 also. if you have any of the 3 programs installed on your machine you should be able to export directly from revits api, Tools menu -> external tools... from cad nwcout is the command. if you are unable to do these go into the control panel and change/remove navis and add the exporters, you may also need to repair the installation if navis was installed after cad and revit.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:18 AM
Revit 2010 and Navisworks 2010
Mon, Mar 1, 2010 at 8:15:35 AM
Revit and Navisworks
Tue, Nov 27, 2012 at 2:36:00 PM
REVIT X ADT
Sun, Jan 8, 2006 at 10:40:42 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
Page generation time: 5.8259
