Forums >> Revit Structure >> Technical Support >> Image File not Alligned?
Thu, Mar 12, 2009 at 12:52:20 PM | Image File not Alligned?
WhitmerEngineering
I have a problem in Revit Architecture.  I am designing a floor for a room with a big tile design in the middle.  I set the floor to a finish and put an image file in for it.  The image is a big panther, however, every time I render the image the panther is not centered.  Instead of one large centered panther, 4 pieces of one show up, off center.
I have done everything I can think of, can someone please help?
Thu, Mar 12, 2009 at 1:36:50 PM | Image File not Alligned?
It looks like you used this as a finish material instead of a decal and the pattern start is in the middle of your space.  I'm not sure how you can control this.  But if you place this pattern as a decal on the floor, it should work.
Thu, Mar 12, 2009 at 2:26:19 PM | Image File not Alligned?
4 Stars: 205 Votes
You must adjust the values of the image....
Thu, Mar 12, 2009 at 2:43:57 PM | Image File not Alligned?
Typhoon - I think the size is OK ... just the repeat location.... seems to be centered on his space rather than one corner.
Thu, Mar 12, 2009 at 3:07:30 PM | Image File not Alligned?
4 Stars: 205 Votes
Hummm, what about "Split Face" that floor in the place you want and Use the "Paint" tool with that "texture"????
Thu, Mar 12, 2009 at 3:10:46 PM | Image File not Alligned?
Typhoon - I think he has to somehow control his pattern origin.   I have not done that enough to know how.  That's why I suggested just pasting it as a decal on the floor
Thu, Mar 12, 2009 at 3:55:36 PM | Image File not Alligned?
4 Stars: 205 Votes
WWhub, yeah, the decal works fine, i know that, but if he don't want to use that what he can do is "Crop" the image with the right measure in a external software (photoshop) then use that system (split-paint) and adjust the values to fix the "right" image in the "split Face".... and in this way the image appears in the center.....
Fri, Mar 13, 2009 at 11:58:57 PM | Image File not Alligned?
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
what you really want to do is use the texture alignment tool in the material rendering settings to align it to the shaded view surface pattern:
Hiroshi Jacobs
Roof layers not alligned
Tue, Aug 31, 2010 at 2:07:38 PM
Wall end at an angle
Tue, Jan 26, 2010 at 5:03:27 AM
Locking inserted image/dwg file
Mon, Aug 29, 2011 at 9:38:25 AM
Export an Image shortcut help.
Wed, Feb 10, 2021 at 10:33:57 AM
Image export
Sat, Oct 24, 2009 at 6:25:00 PM
Page generation time: 0.6593
