Forums >> Revit Structure >> Technical Support >> Stuck with Line Weights......
Thu, Mar 12, 2009 at 10:11:07 AM | Stuck with Line Weights......
Allan1983a
I am doing a Slab Drawing, in Plan the edge of the Slab in Cyan to give the thickest possible line.  However when I then add a section through this to show the steel below it is still cyan is there a way to change this??? I have tried greying it out and making it halftone but it still makes a thick line, I also wish to avoid the Linework command as I have a number of Slabs over a number of levels! Anyones help ASAP would be greatly appreciated as im trying to meet an issue deadline!
 Cheers
Al
Thu, Mar 12, 2009 at 11:12:20 AM | Stuck with Line Weights......
I really don't understand what you are doing.  Revit's lineweights have nothing to do with color!  I suggest you read your HELP and look at settings/object styles....
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 0.6309
