Forums >> Revit Building >> Technical Support >> Metal siding
Fri, Jun 24, 2005 at 12:38:28 PM | Metal siding
timOthyj
4.5 Stars: 14 Votes
Iam looking for texture maps and patterns of metal siding, not straight across siding but curved siding . ANyone know of any?
Fri, Jun 24, 2005 at 5:29:20 PM | RE: Metal siding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've found this site to be invaluable.... http://www.steelselect.com/resource_library/link_index.php?link_id=41
Sat, Jun 25, 2005 at 4:46:19 PM | RE: Metal siding
timOthyj
4.5 Stars: 14 Votes
Thats a fantastic link... I just took one of the images into photoshop and did a offset so where it would have a seemless edge. Thanks!
Sat, Jun 25, 2005 at 5:07:06 PM | RE: Metal siding
timOthyj
4.5 Stars: 14 Votes
Okay I found a file that I can use for a fill pattern how do I import that file into a .pat extension?
Sat, Jun 25, 2005 at 9:20:58 PM | RE: Metal siding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Images cannot be imported to pat files to create hatches... I thought you wanted the images for rendering? Anyways the best way to create hatch patterns is using a program called Hatch Kit (not free). Otherwise you'll either have to find the appropriate hatch pattern somewhere or from someone, or learn how to write pat files using online tutorials (I gave up and just bought the program is not very expensive and very handy to have). Cheers.
Mon, Mar 16, 2009 at 9:44:10 PM | Metal siding
rierie
Thank you for the link to steelselect.com. It's great.
If I want to create a custom colored metal siding based on the .bmp on this site, how do I go about it?
Here's how I've been doing it but I just get a flat color when I render. The swatch I made show some subtle pattern, though.
Render Appearance Based on: I picked Generic
Scene: I tried both Default and Flat, but did not make a difference
Generic Material Properties: I picked a color I liked - Single Color.
Bump Pattern: I picked image file,   one of the grey corrugated .bmp pattern that I downloaded from steelselecct
Amount: I picked single value, and played with the sliding scale. 1 seems to work best on the swatch.
I haven't touched anything else on the rendering setting.
I'm probably doing something really obviously stupid here... please help. Thanks in advance!!
Looking for source of metal siding rendering patterns.
Thu, Mar 22, 2007 at 7:40:40 PM
metal building question
Fri, Dec 20, 2013 at 8:39:28 PM
demolish siding
Mon, Oct 6, 2008 at 1:59:36 PM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Siding Sweep Return
Sun, Oct 30, 2011 at 5:57:53 AM
Page generation time: 5.5101
