Forums >> Revit Building >> Technical Support >> dimension number size
Wed, Mar 11, 2009 at 10:43:54 PM | dimension number size
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
if i open a new project to the default template
and hit the wall tool and drag a wall- the
temporary blue dimension number is
almost too small for me to read.. is
there any way to change that?
Thu, Mar 12, 2009 at 4:56:53 AM | dimension number size
4 Stars: 205 Votes
I saw the same question in a thread but I don't know if it was here in RevitCity, but I think you must edit the "Revit.Ini" file and change the value wich control that "temporary Dimension".... try to search here in the forum....
Thu, Mar 12, 2009 at 12:08:15 PM | dimension number size
coreed
coreed Avatar
4 Stars: 16 Votes
here it is
http://revitclinic.typepad.com/my_weblog/2009/01/temporary-dimension-size.html
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Mar 12, 2009 at 5:06:43 PM | dimension number size
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks coreed-
i found the revit clinic on temporary dimension text size.
12 is most recommended instead of the default 8..
what a pleasent relief to actually see those blue numbers clearly..
Thu, Mar 12, 2009 at 5:23:34 PM | dimension number size
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
there must be a good reason why the revit program
designers chose to keep the temporary dimension
text size small.. i put it on 10 just to play
it safe.. 10 is also quite readable..
Tue, Mar 9, 2010 at 8:46:33 AM | dimension number size
NickStanley
Does anyone know a fix for Revit Architecture 2010. The .ini does not have that line in it (TempDimFontSizeInPoints=N).
Thanks
Tue, Mar 9, 2010 at 9:36:37 AM | dimension number size
Dafpfy
3.5 Stars: 11 Votes
[Graphics]
TempDimFontSizeInPoints = 12
Just past this at the bottom of the ini file.
i just did it and worked for me,
also the measure dimensions are bigger,,, great !! Smile
Edited on: Tue, Mar 9, 2010 at 9:46:07 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Mar 9, 2010 at 9:42:20 AM | dimension number size
NickStanley
YES! I can see the dims, Thank you!
Tue, Mar 9, 2010 at 10:08:48 AM | WYS1WYG
TomDorner
4.5 Stars: 25 Votes
Quoting WYS1WYG from 2009-03-12 17:23:34
I think it is because they are all younger with 20/20 vision.  The need to get some feed back from those of us in our 50's with multi-focal lenses!  I need the large type edition of Revit now!
Tom
Wed, Apr 7, 2010 at 3:39:05 PM | dimension number size
iamian33
iamian33 Avatar
This solution works great, except that now, when I place a wall, door or window, the listening dimensions do not show any text ... Can anyone advise on what I can do to correct this?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Window Number under dimension
Mon, Jun 8, 2015 at 6:40:26 PM
Room number rectangle size
Thu, Sep 5, 2013 at 1:03:25 PM
How to change the number size on the tape tool and on the cursoe
Sat, May 1, 2010 at 4:46:44 AM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:10:20 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Page generation time: 0.6731
