Forums >> Revit Building >> Technical Support >> file archives
Fri, Jun 24, 2005 at 11:36:52 AM | file archives
jclark53
Do any Revit users have any suggestions about archiving files for permanent storage? Is there any way to condense files after purge?
Fri, Jun 24, 2005 at 5:24:35 PM | RE: file archives
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit files are much like jpg files and are already pretty much as condensed as they are going to get. You could try zipping the files but it won't make much difference. Our projects, once completed are typically archived to DVD's and set away for storage.
Sun, Jun 26, 2005 at 4:01:32 AM | RE: file archives
Xane
Is there some way to make archive with all files which we use, like material lib's and map files etc for each project or when we move project to other PC.
Sun, Jun 26, 2005 at 6:28:14 AM | RE: file archives
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not really, i mean you could include them all in a zip file with directory structures intact... But i'd just suggest keeping all the maps, material libs etc in a central location where nothing gets deleted from and back that up systematically...
Sun, Jun 26, 2005 at 8:22:07 AM | RE: file archives
Xane
I am doing that but I hope that we will get 'archive' or 'packing' project in the future, something like Microstation have.
Wed, Jun 29, 2005 at 11:04:14 AM | RE: file archives
jclark53
Thanks for the responses. I agree there needs to be an easier way to pack projects away. Mr. Spot: When you archive to DVD, do you just copy everything over? Or do you have to actually Save To Central using the DVD writer? I am having trouble getting either one to work properly.
Wed, Jun 29, 2005 at 5:23:47 PM | RE: file archives
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We just copy everything over. The information is being archived so if the file no longer remembers itself as being the central file then that't not really an issue. If the file needs to be used at a later date it can easily be resaved from the dvd as a central file (although if placed back in the same directory path as it was originally it should become the central file again. HTH.
Thu, Jun 30, 2005 at 8:53:34 AM | RE: file archives
jclark53
Thanks. I appreciate all the help.
Mon, Feb 22, 2010 at 6:47:16 AM | file archives
notagain
notagain Avatar
4 Stars: 1 Votes
Mr Spot....the problem I am having ..... we will on average 30 to 50 revit models ref to a project....I have models converted into Revit from different disciplines.  Any suggestions for an animal like this?
I really want this to work...some good things some bad
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:43 AM
A must read for all fans of Revit/BIM technology
Thu, Apr 19, 2007 at 8:36:15 AM
importing table from word
Wed, Jul 3, 2013 at 8:37:01 AM
Lets-play-a-game-of-revit-jeopardy
Fri, May 11, 2012 at 2:38:31 AM
How many local files to keep??
Tue, Oct 6, 2015 at 4:05:44 PM
Page generation time: 3.5407
