Forums >> Revit Systems >> Technical Support >> Insulation and Lining thickness for ductwork issue
Wed, Mar 11, 2009 at 7:20:17 AM | Insulation and Lining thickness for ductwork issue
jcrocco
3 Stars: 1 Votes
Is there a way in MEP2009 to draw the ductwork already lined or insluated?  It seems difficult to do after the design is complete.  When I select the whole system, it wont give me the option to modify the element properties.  I can select the ductwork only, but then it doesnt do the fittings.  I can do the fittings seperately, but that is time consuming as it wont do fittings of different types at the same time.
I would think there is a way to draw the ductwork with the insulation or lining specified, I just dont know where.
I would also think there is a way to easily modify the whole system to be lined or insulated.
Am I thinking to much, or is Autodesk not thinking enough?
Wed, Mar 11, 2009 at 9:41:18 AM | Insulation and Lining thickness for ductwork issue
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
ADSK may not be thinking this one trough yet, you have to go back after the fact its the same with piping.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Cant find ductwork lining settings and fitting settings.
Tue, Apr 7, 2009 at 10:44:56 AM
Duct Tags
Thu, Jul 31, 2014 at 3:43:41 PM
Door Lining Depth
Thu, May 3, 2007 at 2:39:56 AM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Plumbing insulation
Thu, Feb 20, 2014 at 8:19:48 AM
Page generation time: 1.9542
