Forums >> Revit Structure >> Technical Support >> Column base attachments - RS 2009
Tue, Mar 10, 2009 at 12:17:42 PM | Column base attachments - RS 2009
JamieH2304
Hi All
I have a series of RC columns, 400x400 founded on pile caps up to roof level.  Revised design means these column from foundation to 1st floor are to become 500x500, then 400x400 to roof.  I have tried to fix the base to First Floor Level in the columns properties, but it wants to take the foundation with it which is attached.  I ahve tried detaching but that won't let me pick the pile cap as the object to detach.  The warning tell me as I try to change the column base tells me that the pile cap will follow to level 1 but this 'warning can be ignored'.  Like hell it can't, it can if I delete the column or ignore it by leaving the column as 400x400 all the way up but thats not what I want.
Any ideas guys without having to redraw?
Jamie
Jamie Hunter
Walsh CE
Graphical House,
2 Wharf Street,
The Calls,
LEEDS.
LS2 7EQ
U.K.
www.walshgroup.eu.com
Thu, Mar 12, 2009 at 9:06:13 AM | Column base attachments - RS 2009
mholzer
4 Stars: 1 Votes
I as well cannot find a way to detach a column from its footing without redrawing.
No one else has suggestions?
Fri, Mar 13, 2009 at 6:22:37 AM | Column base attachments - RS 2009
JamieH2304
Anyone, even if it is to suggest that it is a case of having to redraw?
Jamie Hunter
Walsh CE
Graphical House,
2 Wharf Street,
The Calls,
LEEDS.
LS2 7EQ
U.K.
L shape wall without removing top and base attachments
Tue, Jun 3, 2014 at 7:33:43 AM
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:40 PM
Base Plates & Graphical Column Schedules
Mon, Feb 22, 2010 at 11:51:01 AM
Isolated Foundation atching to column base: Revit 2010
Thu, Jun 25, 2009 at 1:59:29 AM
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM
Page generation time: 0.2656
