Forums >> Revit Structure >> Technical Support >> Maintain phasing when copying elements - how?
Tue, Mar 10, 2009 at 10:35:26 AM | Maintain phasing when copying elements - how?
dlewy
Here's my situation. I'm placing a bunch of existing footings and have the ones I've already placed set to "Existing" phasing in the element properties. However, when I copy one of the footings that I have set to "Existing", the new one that I place switches back to "New Construction" phasing in the element properties.
 Is there a setting that can be adjusting to make it so when I copy elements it maintains the phasing setting?
 Thanks for any help
Tue, Mar 10, 2009 at 10:02:08 PM | Maintain phasing when copying elements - how?
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Yeah, all new elements are "created" in the same phase that the view is set to.  So if you set the view properties phase to "Existing" and then copy the elements they will be created in the Existing phase.
Hiroshi Jacobs
Wed, Mar 11, 2009 at 8:21:27 AM | hjacobs
dlewy
Quoting hjacobs from 2009-03-10 22:02:08
"Yeah, all new elements are "created" in the same phase that the view is set to.  So if you set the view properties phase to "Existing" and then copy the elements they will be created in the Existing phase."
Well now doesn't that make sense! Thanks, problem solved Smile
PHASING
Tue, May 20, 2008 at 1:57:25 PM
Copying elements from a linked architectural model into my host structural model
Thu, Feb 12, 2015 at 4:30:35 AM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:00 PM
Phasing Graphics and Detail Level
Wed, Jan 13, 2016 at 11:24:29 AM
Phasing Not Working For Me! Help Needed Please.
Fri, Jun 25, 2010 at 9:04:35 AM
Page generation time: 1.6085
