Forums >> Revit Building >> Technical Support >> View Heads - callout to match section/elevation heads
Tue, Mar 10, 2009 at 9:58:00 AM | View Heads - callout to match section/elevation heads
blackhawk
3.5 Stars: 3 Votes
Greetings,
 I have looked through the forums and could not find the specific answer I was seeking. I'm having issues matching the callout head size with the section head size/scale. I've tried to edit the system family but it seems as if both are using the same text sizes but when loaded into Revit, the scale and text sizes are different...See attached image.
 -Is there a way to match the sizes of all view heads - callouts, elevations, sections?
Thanks
Tue, Mar 10, 2009 at 2:15:06 PM | View Heads - callout to match section/elevation heads
Someone has edited the family because the standard does match.  When you edit the family - look beyond the name of the text - look at the text properties.  Careless users will change the size without changing the name.
Mon, Mar 23, 2009 at 3:00:21 PM | View Heads - callout to match section/elevation heads
blackhawk
3.5 Stars: 3 Votes
I finally figured it out. Thanks for the tip.
Basically I had to create a new annotation callout head and load it into the project (but it gets 'lost'). In doing so, I matched all the text properties as mentioned by WWHub, and I matched the diameter of the existing family. I had to dive deeper than the basic 'family:properties, edit family' because with tags, the family wasn't the issue, the header/tag was. That is in itself a type within the tag family. By using this method->  settings: view tags: callout tagsSadselect the newly create tag) I was able to rectify my situation. Case Closed.
The easier way to edit the type is by selecting the head under the annotations in the project browser. DOH!
Regards,
Section heads - (Revit 2010)
Mon, Nov 16, 2009 at 12:48:38 PM
Section Heads
Sat, Jun 10, 2006 at 9:49:47 PM
Similar and Opposite call out heads
Tue, Jun 5, 2007 at 10:23:38 AM
Section & Callout Heads
Wed, Feb 13, 2008 at 11:53:14 AM
Section Heads
Tue, Nov 24, 2009 at 4:51:48 PM
Page generation time: 2.0012
