Forums >> Revit Building >> Technical Support >> problems with metal roof surface pattern
Tue, Mar 10, 2009 at 2:02:45 AM | problems with metal roof surface pattern
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
For some reason when I rotate view on the sheet, roof surface pattern (metal roof) does not rotate and stays in the same position as it was before rotation. Also same problem with this second roof, pattern is not following the rotation of the roof. Have a look at these attachments and let me know how can this be fixed? Thanks
Sloped roof surface pattern grayed.....Revit 2015
Thu, Jan 15, 2015 at 1:48:15 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Surface Pattern Problems - Basic Roof
Fri, May 2, 2008 at 2:41:11 PM
Surface pattern problems
Sat, Jul 23, 2011 at 8:29:46 PM
Page generation time: 1.2695
